14 years agodmx-512 vhdl/verilog code
can any one plz help me for my project. titled dmx-512 protocol used to control led brightness in video display systems..
14 years agoi have written the code for 100 channels also but iam getting some warnings like below.,
Warning: No exact pin location assignment(s) for 813 pins of 813 total pins Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'. Warning: Found 802 output pins without output pin load capacitance assignment Warning: Can't generate programming files because you are currently using the Quartus II software in Evaluation Mode Warning: Found pins functioning as undefined clocks and/or memory enables Info: Assuming node "SysClk" is an undefined clock Warning: Found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew Info: Detected ripple clock "RxUnit:RxDev|Start" as buffer Warning: Circuit may not operate. Detected 38 non-operational path(s) clocked by clock "SysClk" with clock skew larger than data delay. See Compilation Report for details.
