15 years agoDMA problem
hello, i am using on chip memory on altera de2 board to store my program code written in C and C++. May i know what is the ideal size for the on chip memory. currently, i set it to 1mb but i am afrai...
15 years agoDid you compile your hardware design? I doubt that 1mb would fit in the FPGA used on on the DE2 board.
When you compile the software, it will tell you how much memory is used by the code and data. Then you need a bit more for the stack and heap memories, but this depends on your code.
