14 years agoDisabled JTAG circuitry pins connection
Hallo, I have to connect a daughterboard to a system of my own (main board) which is almost pin-compatible with my previous design. The only problem, is that for a JTAG which I will not use in...
14 years agoThank you very much, I thought also the same way... if TCK performs no flanks should TDI and TMS not be taken into account by the slave JTAG in the FPGA... I only hope it will not explode when I switch it on ;)
