Robert_PIN_ASAP
2 years agoDisable scrambler for 10GBASE-R on Cyclone 10 GX?
Hello, I'm not able to find a valid configuration for disabling the TX scrambler using the Cyclone 10 GX when configuring the transceiver for 10GBASE-R. Note that this is for testing, and the RX p...
Kshitij_Intel
2 years agoHi,
If you are choosing Transceiver Configuration Rule to 10G Base-R or Interlaken. You cannot just disable scrambler with your current configuration. Also, if you choose Basic (Enhanced PCS) you can disable the scrambler, but you also need to disable the 64b/66b encoder.
Thank you,
Kshitij Goel
