15 years agoDifferential to Single Ended Signal Conversion
Is here a Quartus Megawizard function that converts from differential to single ended signaling?
The ALTIOBUF can be used to create differential from single ended (I'm using it in this design), but I need to change it back from differential to single ended. I've looked up different LTspice circuits for it, but they do not seem applicable in a Quartus environment. thanks **I actually just found ALT_IOBUF_DIF, and am going to try to work it into my design. we'll see if Stratix III supports this one... **Stratix II does not support this instance sadly... ** Solved the problem.No RepliesBe the first to reply
