15 years agoDifference between IORD_32DIRECT and IORD_ALTERA_AVALON_PIO_DATA
Hallo,
could someone explain me the difference between IORD_ALTERA_AVALON_PIO_DATA and IORD_32DIRECT? When should I use which? Thanks Sim5 Replies
--- Quote Start --- sim, the register is always a 32 bits register if your pio has a 1 bit width the other bits are going to be zero --- Quote End --- That makes sense! Thank you. - Altera_Forum
if your pio has a 1 bit width the other bits are going to be zero - Altera_Forum
from altera_avalon_pio_regs.h
# define IOADDR_ALTERA_AVALON_PIO_DATA(base) __IO_CALC_ADDRESS_NATIVE(base, 0) # define IORD_ALTERA_AVALON_PIO_DATA(base) IORD(base, 0) # define IOWR_ALTERA_AVALON_PIO_DATA(base, data) IOWR(base, 0, data) # define IOADDR_ALTERA_AVALON_PIO_DIRECTION(base) __IO_CALC_ADDRESS_NATIVE(base, 1) # define IORD_ALTERA_AVALON_PIO_DIRECTION(base) IORD(base, 1) # define IOWR_ALTERA_AVALON_PIO_DIRECTION(base, data) IOWR(base, 1, data) # define IOADDR_ALTERA_AVALON_PIO_IRQ_MASK(base) __IO_CALC_ADDRESS_NATIVE(base, 2) # define IORD_ALTERA_AVALON_PIO_IRQ_MASK(base) IORD(base, 2) # define IOWR_ALTERA_AVALON_PIO_IRQ_MASK(base, data) IOWR(base, 2, data) # define IOADDR_ALTERA_AVALON_PIO_EDGE_CAP(base) __IO_CALC_ADDRESS_NATIVE(base, 3) # define IORD_ALTERA_AVALON_PIO_EDGE_CAP(base) IORD(base, 3) # define IOWR_ALTERA_AVALON_PIO_EDGE_CAP(base, data) IOWR(base, 3, data) # define IOADDR_ALTERA_AVALON_PIO_SET_BIT(base) __IO_CALC_ADDRESS_NATIVE(base, 4) # define IORD_ALTERA_AVALON_PIO_SET_BITS(base) IORD(base, 4) # define IOWR_ALTERA_AVALON_PIO_SET_BITS(base, data) IOWR(base, 4, data) # define IOADDR_ALTERA_AVALON_PIO_CLEAR_BITS(base) __IO_CALC_ADDRESS_NATIVE(base, 5) # define IORD_ALTERA_AVALON_PIO_CLEAR_BITS(base) IORD(base, 5) # define IOWR_ALTERA_AVALON_PIO_CLEAR_BITS(base, data) IOWR(base, 5, data) - Altera_Forum
Ok. That means, if I use both commands for a PIO, they work similar. Right?
But wherefrom does IORD_ALTERA_AVALON_PIO_DATA know the width of the data? I mean in the other case I specify 8, 16 or 32 Bit. And what does IORD_ALTERA_AVALON_PIO_DATA if the width is 33Bit for example? - Altera_Forum
IORD_ALTERA_AVALON_PIO_DATA reads the data from a PIO
IORD_32DIRECT reads 32 bits from an adress (that can be a pio)
