13 years agoDHCP with TSE?
Hi, is it possible to set different ip-addresses via PC without NIOS & Co into TSE-IP-Core? I'll use one PC/ETH-Switch and e.g. three separate Cyclone V-GX devices with TSE-SGMII-PMA-PHY....
13 years agoSince you aren't using software, you would have to visit the relevant documentation for whatever blocks are generating the ethernet packets being supplied to the TSE. If there are multiple such blocks, you would possibly need to supply each of them with the IP address.
