18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years agoThe design uses a lot fo FIFO's and you could see the difference in the number of lcells and registers being used in the ones without the block ram and that ones with. I'm sure if all the fifo's used block ram then there would probably be problems again.
