18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years ago --- Quote Start --- We've solved this one now. Not all the FIFO's we're using block ram - some use registers because it's move efficient. Altering that ratio - putting more in block memory solved the problem. --- Quote End --- Great, when you look to the resources for the entities did you see an unusual ratio between the number of LCELL and Registers for the block where the Fifos are in ?
