18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years agoWe've solved this one now. Not all the FIFO's we're using block ram - some use registers because it's move efficient. Altering that ratio - putting more in block memory solved the problem.
