18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years ago --- Quote Start --- Yes, it did. I've disabled most of the logic that I added and kept it to it's minimum. I've tried many combinations of options and the best ones (as usual the original ones) puts the design 18 labs too big. Does Quartus do multiple attempts if it fails to fit? Is there a way of finding out quickly that it's likely to fail? --- Quote End --- The fitter tries a maximum of 3 placement and routing attempts, with each successive attempt increasing the placement effort and hence increasing compilation times. You can limit it to one attempt. Settings -> Fitter Settings -> Limit to one fitting attempt When the design fits, what was the device utilization, the peak and the average routing usage ? What kind of design is it ? Digital signal processing ????
