18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years ago --- Quote Start --- Fitter Preservation Level: Allows you to specify the amount of information that you want the Fitter to preserve from the specified netlist file. Fitter Preservation Level is only available when Full incremental compilation is turned on. --- Quote End --- Does the design fit into the FPGA before you changed it ?
