18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years ago --- Quote Start --- Some settings: 1. physical_synthesis_map_logic_to_memory_for_area = on 2. physical_synthesis_combo_logic_for_area = on 3. fmax is set to 125MHz 4. mux_restructure = on 5. allow_any_ram_size_for_recognition = on 6. allow_any_rom_size_for_recognition = on 7. allow_any_shift_register_size_for_recognition = on 8. auto_packed_registers_stratixii = minimise area 9. fitter_effort = standard fit 10. router_effort_multuplier = 2.0 11. router_timing_optimization_level = maximum 12. partition_fitter_preservation_level = placement and routing 13. smart_recompile = on 15. stratixii_optimisation_technique = area It takes several hours just to get to the fitter stage. Regards MT --- Quote End --- Hi, are you using design partitions in your Quartus project ? If, yes try a run where you remove all design partitions. Another reason could be memory description which are not recognized or could not implemented in the memory of the FPGA. So have look to the to the compilation report : Analysis & Synthesis -> Resource Uitlization by Entity Are memory and DSP blocks (e.g.) used etc......
