18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years agoSome settings:
1. physical_synthesis_map_logic_to_memory_for_area = on 2. physical_synthesis_combo_logic_for_area = on 3. fmax is set to 125MHz 4. mux_restructure = on 5. allow_any_ram_size_for_recognition = on 6. allow_any_rom_size_for_recognition = on 7. allow_any_shift_register_size_for_recognition = on 8. auto_packed_registers_stratixii = minimise area 9. fitter_effort = standard fit 10. router_effort_multuplier = 2.0 11. router_timing_optimization_level = maximum 12. partition_fitter_preservation_level = placement and routing 13. smart_recompile = on 15. stratixii_optimisation_technique = area It takes several hours just to get to the fitter stage. Regards MT
