18 years agoDesign won't fit in device
Hi, I'm trying to get a design to fit in a Stratix III EP3SL340H1152CS device. I get an error saying that the fitter requires 13555 LABs to implement but device only contains 13520 LABs. ...
18 years ago --- Quote Start --- Hi, Your resource problem is the logic, not memory blocks as indicated by the error message(LABs). The notion of 85% or so is sort of rule of thumb for fmax. The fitter doesn't follow this rule. It will fit as long as there is resource until 100% if necessary. Kaz --- Quote End --- What settings are using ? E.g. optimize for speed or physical synthesis ....
