15 years agoDesign Size and the timing accuracy
Dear Sir, I've met one problem. It is about the design size and timing accuracy. If I have a design which used up the FPGA 95% or above LEs, is it going to have some I/Os having worse tim...
15 years agoDear GPK,
Thanks for your comment. I believe SDC is important for the timing constraints. However, is it possible that the requirements of my design are over that FPGA could provide in timing, especially while the available LEs are less. Regards, Peter Chang
