10 years agodesign examples, qsys and base addresses
Im working through a web server design example. It has an iniche stack. I rebuild the qsys to reflect the newer quartus version changes. i made no other changes, but i did update the base addresse...
10 years agoDid you rebuild the NIOS BSP? After doing so, make sure the addresses in the software match what Quartus is using.
