18 years agoderive_pll_clocks cmd and it's generated clk
Hi, I have a question regarding derive_pll_clocks. Quote taken from QII Handbook Vol 3 pg 6-36 Under title Derive PLL Clocks "If you use the write_sdc command after the derive_pll_clock ...
18 years agowrite_sdc still works like it used to if you use "write_sdc -expand".
From the on-line help for write_sdc: --- Quote Start --- Generates an SDC file with all current constraints and exceptions. When you use the -expand option, derive_clocks, derive_pll_clocks, derive_lvds_clocks and derive_clock_uncertainty macros are be expanded to corresponding sdc assignments before they are written to a file. If you do not use the -expand option, these macros are preserved. --- Quote End ---
