18 years agoderive_pll_clocks cmd and it's generated clk
Hi, I have a question regarding derive_pll_clocks. Quote taken from QII Handbook Vol 3 pg 6-36 Under title Derive PLL Clocks "If you use the write_sdc command after the derive_pll_clock ...
18 years agoThanks Rysc, I get it now.
I think Altera should update it's Handbook information since the write_sdc command has been changed and no longer write out individual PLL generated clocks. This is to avoid poor souls like me (noob) thinking over and over again if I've did sth not right. :p Thanks again!
