18 years agoDeos the plls of a fpga exactly same?
Hi, I have questions about pll. 1. If I use one clock source(27MHz) driving two plls in one fpga, and the parameter of plls is the same(generate 135MHz, but phase is same or different), Can ...
18 years agoThanks Rysc. Very interesting post and design, as usual.
Unfortunately it's useless in my case. I need to use the dedicated PLL output pins. That's the reason I wanted to use two different PLLs in my case. Otherwise, I could simply use a single PLL. I guess I would need to use a single PLL and compensate the delay and jitter manually.
