15 years agoDebugging interface issue on FPGA
Hi, I have a data processing module that takes only clock and reset as input and generate an expected sequence of data. When this design is tested in stand-alone mode, it works fine. But when i...
15 years agoThe data generated is sent off the chip to other device.
The data is passed through a DAC and observed on oscilloscope. In stand-alone mode, the output on oscilloscope is repetitive with a fixed pattern. When integrated in bigger system, the output is still repetitive but the pattern is wrong. I made sure that my module takes only clock and reset as input when integrated in bigger system to isolated data dependency problem. This integration of bigger system is done by a different team at different location and I do not have access to the board. Thanks
