17 years agoDE2-PC communication
Hi All I am doing some project using Altera's DE2 board, In which I need to load on board RAM (SRAM) from PC. I am planing to use USB for that but I dont know to start with it. there are...
17 years agoVHDL code or AHDL verilog or bdf are translated into sof/pof files to program the device (on Quartus software) .The configuration data is transferred from the
host computer (which runs the Quartus II software) to the board by means of a cable that connects a USB port on the host computer to the leftmost USB connector on the board. To use this connection, it is necessary to have the USB-Blaster driver installed. Or look for Altera’s DE2 Board for information about installing the driver. Before using the board, make sure that the USB cable is properly connected and turn on the power supply switch on the board. Thetre two possible ways of programming In the JTAG mode and Active Serial (AS) mode.
