17 years ago
DE2 board USB communication
Hello people,
I'm curious to know is there anyone who have experience with DE2 board USB communication ?
There is some ISP1362 USB-OTG controller which must be appropriate configured in order to communicate with USB device plugged into DE2 USB connector.
Does anybody worked with this controller using VHDL programming language ?
Is there a lot of problem to configure ISP1362 USB-OTG controller ?
Thank you very much,
Bojan
    hello
    I am now working in a project which needs to make the DE2-70 board as a USB device and the host is the PC.
    I write some codes in vhdl to communicate with the ISP1362, because I can not to use the NIOS processor...
    When I try to probe the system, I found these problems:
    1) If I connect both the blaster cable and the device cable to the pc or only the blaster, the host
    shows initially the blaster, then I download the firmware to the FPGA and the system do the Enumeration and initialization
    process and the ISP1362 is recognize by the host PC. But, if I disconnect the blaster cable, the system
    is not respond, then I reset the driver by the firmware and the device is doesn't show by the host.
    I am using the VISA USB Raw of National Instrument and its driver in the host.
    2) If I work with both the blaster cable and the device cable connected, the system can transmit data
    from PC to device successful, but when I try to send data from device to host PC, it show me a timeout error. I check the firmware step by step and it apparently work correctly.
    Could you help me with these????
    Hi Koce,
    to build up your USB communication you will have to configure your Philips ISP1362 USB-OTG controller from your VHDL code. Given that a simple Nios-II only takes a few procent of the Logic Elements on your DE2, it is probably the easiest to realize your USB communication via a Nios processor and using a JTAGUART.
    Thank you anyway...
    But there is no visible code for this examples, and USB
    controller is configured using Nios II processor. I want to use VHDL to configure controller.
    Bojan
    There are a number of ways that you can communicate via USB on the DE2 board.
    1. You can set up a Nios-II architecture in SOPC and add a JTAGUART. You can use the JTAGUART to communicate from the Nios-II to your PC
    2. On the CD-ROM that goes with the DE2 there is an example DE2_USB_API in the "DE2_emonstrations" Folder.
    3. See the DE2_UserManual.pdf section 4.14 "Using USB Host and Device".
    Hope this helps...
