17 years agoDE2 board USB communication
Hello people, I'm curious to know is there anyone who have experience with DE2 board USB communication ? There is some ISP1362 USB-OTG controller which must be appropriate configured in order to...
16 years agoHi,
I’m modifying the firmware coding of device controller which found from DE2 CD. My target is to send 16 bytes data block per transmission. I had modify the coding from ISR.c and mainloop.c But I still fail to make it transfer 16 bytes data per packet. (this is the coding from interrupt service routine,ISR.c) void Isr_Ep02Done(void) { unsigned char bbuf[16]; int i = 0; Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP02); Hal4D13_ReadEndpoint(EPINDEX4EP02,&bbuf, 16); //error was found here : passing arg 2 of //'hal4d13_readendpoint' from incompatible pointer type. if( sendCount < length) { Hal4D13_WriteEndpoint(EPINDEX4EP02, data + sendCount, 16); Hal4D13_GetEndpointStatusWInteruptClear(EPINDEX4EP02); sendCount += 16; if(sendCount > length) { sendCount = 0; length = 0; for( i = 0; i < 65; i++) data[i] = 0; } } } Can anyone give me suggestion on how can I debug this error? I’m stuck…. Thanks, Summer
