15 years agoDE2-70 and I2C
Dear Sir, If I want to design an I2C port on the FPGA, like DE2-70, do I need an I2C bus extender? How to add it onto the DE2-70? I've one example design from the I2C bus extender, P82B96 ...
15 years agoDear Nicolas,
Thanks for your sharing. Let me explain more about my case. The problem I met is when I'm using an I2C interface between the DE2-70 and external board via a falt ribbon cable. In the case, it may need an extender, because the signals, SDA and SCL are not as stable as that I expected. Do you think so? Thank you! Regards, Peter Chang:confused:
