10 years agoDE2-115 Triple Ethernet nios download fails
Hi, Im trying to use the triple ethernet example for my de2-115 board. I am using quartus 13.0. I follow the tutorial, and compile it. It compiles just fine. Im using the Eclipse Nios tool ...
10 years agoHi Galfonz
I should have mentioned that ive created several projects already, so im familiar with the build process. I have this particular board working over jtag uart to control a couple of spi interfaces to a device under test. So i know the board is working correctly. Im just having some issues with the ethernet examples. Can you help? thanks
