8 years agoDE2-115 board with DCC AD/DA daughter card
Hi all. I am trying to implement a DDS with altera DE2-115 board. I want to use only the DAC of the daughter card. My codes run, no errors, in modelsim I can see the input thats gonna go in th...
8 years agoHi again
I am finally getting some output in the oscilloscope, I had to make some adjustments in my code. But I find the DAC output signal is better for lower frequency, the signal degrades for higher frequencies. I have seen this in the case of the signals generated in the demo version too. The DAC spec mentions the max clock can be 275 MHz, doesnt mention any minimum. I tried doubling the DAC clk input (100MHz), doesnt improve much. Can you suggest any way which can improve the signal in higher frequencies? Thank you so much!- Owen-Tan2 years ago
Hi, a newbie here,
I'm currently working on my Final Year Project where I needed to do something similar to yours, except that I am using the DE-10 Standard Board instead of DE2-115. I'm wondering what did you change on your code to be able receive output in your oscilloscope? My modelsim simulation shows the signal I'm looking for but the oscilloscope receive no output at all. I have checked the pin mapping and the AD/DA card clock A and B over and over again but I cant seem to locate the issue. Mind sharing your solution?
Your help will be much appreciated, thank you very much!
