10 years agoDE1-SoC cycling through 7-segment display instead of acting as programmed
I have a DE1-SoC board (ref. F) that is not working as I except. Last week, I designed a full adder in Altera Quartus Prime Lite, which I programmed onto the board successfully. I was able to verify ...
10 years agoThat was an excellent thing to check. The user manual shows this factory default:
https://www.alteraforum.com/forum/attachment.php?attachmentid=12720 The dip switches on the board seemed to match, but I switched them back and forth to make sure they were all the way over, then rebooted and reprogrammed, and now it works. Thank you so much! Ellen
