9 years agoDE0-Nano PLL "non-dedicated routing"
Hi there, I'm having a bit of difficulty getting to the bottom of some warnings to do with the PLL I am using on a Cyclone IV. I'm using the DE0-Nano from Terasic. The 50MHZ onboard oscill...
9 years agoHi,
Go trough reports. 1. Fitter->Resource usage -> PLL Usage (you will see what PLL location is used) 2. In same report location you will found what PLL mode is used. 3. Fitter -> Supressed messages you will found out if there is any supressed messages.
