15 years agoDDR2 pin placement Cyclone 3 HPC II
Trying to meet the (absurdly tight) layout requirements for (32 DQ) DDR2 ram on Cyclone 3. HPC II. The layout engineer keeps trying to move pins (within the x8 DQ groups) and the resulting pin map ...
15 years ago"Critical warning: Fitter could not properly route signals from DQ I/Os to DQ capture registers because the DQ capture registers are not placed next to their corresponding DQ I/Os"
Maybe not fatal, but not something to blindly push past, either. EP3C120F484I7 dq23 = A18 dq22 = A16 dq21 = D19 dq20 = F15 dq19 = E15 dq18 = E16 dq17 = C17 dq16 = C19 dm2 = A17 ds2 = F13 If I swap A17 and A18, the fault goes away, which is surprising because it is actually A16 that is preferred for DM2. There are other swaps that cause this fault, but I don't have the data. Some of the other issues I've seen are now understood as our error.
