18 years agoDDR2 cyclone III FPGA dev kit
Hello, I would like buy the Cyclone III FPGA dev kit. I see that they are on the kit 5 case of DDR2 SDRAM. So I would like know if the code for read and write on the cases is include in the ki...
18 years agoOk thinks, but when I want compile this exemple (nios 2 exemple) I have 4 errors.
Had you the same problem then you had comile the project? https://www.alteraforum.com/forum/attachment.php?attachmentid=506 But I have look the SOPC Builder of the exemple and I have see that only one case is use for the exemple.
