15 years agoDDR Interface SDC Constraint
Hi. I have written a constraint on DDR interface. When I run timing analysis, it shows that it fail in setup time. Based on the ddr example I have seen, it runs at 400MHz. So, my ddr ...
15 years ago --- Quote Start --- Does TQ give you any warnings (besides obvious "critical warning:timing requirements not met)? --- Quote End --- There is no other warning given by TQ. --- Quote Start --- Your refer to clock or data? Can you explain it more details? Thanks
