13 years agoDDIO clock timing
Hi, I'm using a Stratix III EP3SL340 C3 (Terasic DE3) and I had a question about DDIO. I have 12 bit data from an ADC (AFE5807) coming in at 80MSPS. I wanted to use DDIO to receive the da...
13 years agoThank-you rbugalho. I found another great resource as well.
For those stumbling accross this post later on. http://www.ti.com/lit/an/slaa545/slaa545.pdf is a document by TI for interfacing a 250MSPS ADC and DAC with a Stratix IV using ALT DDIO blocks via the LVDS physical interface. Explains the timing relations, clocks, phase relations, constraints etc really well. Cheers Zubair
