17 years agoDCLK after config in PS mode
We're doing a design where we're planning on configuring a EP3C5 using passive serial from a micro controller. We're limited by the number of interconnects and I was wondering about the possibi...
17 years ago --- Quote Start --- There is no problem. In fact the DCLK can be used as a regular I/O on the FPGA after configuration, so you don't need to connect it to an extra I/O. Have a look in Quartus in the device settings, click on the 'Device and pins options...' button, and select the 'dual purpose pins' tab. --- Quote End --- DCLK is a dual purpose pin in active serial configuration. But if you switch the settings to passive serial, the DCLK pin disappears from the dual purpose pin list.
