15 years agoDC offset removal using FPGA?
I am new to interface FPGAs with DSP concepts. I have ADCs and then i have deserializers after them to parallelize the data. So should i apply the DC removal after the deserializer or before it? ...
15 years ago --- Quote Start --- the signal i have is such that at the start of the samples, i have some data i need to ignore, but somewhere in the middle i have the desired data which i need to analyze, does this give some information about what type of filter (bandpass, lowpass or highpass) to be used? --- Quote End --- No, but it complicates your design. How many samples will you have in a continuous block? And how many coefficients will you have in your filter? You may need to have a state machine that allows the filter to fill with valid samples before you consider the output of the filter valid. What you describe is not unusual though. I have digital filters with outputs that have to be ignored for a few microseconds every millisecond, due to a local oscillator being changed. In my case, the logic processing the output of the digital filter is disabled and then re-enabled. Cheers, Dave
