18 years agodatabase solution
Hello everyone, I wish to do database by using c programming in the IDE. For example, user can enter his name and description which will be stored in the flash memory, so that they can retrieve their...
18 years agoMay I ask why you want to implement such a thing?
Well regardless of the why, if I were going to do what you are trying to do, I would write the entire thing in software first on a PC without using an FPGA. There are 3 components to your design: 1 - User input and output 2 - input processing 3 - non-volatile data storage. Number 2 doesn't change at all whether you implement it on a PC or an FPGA. Number 1 could be exactly the same on the PC and FPGA if you get the ps2 input to act like stdin. You haven't mentioned how you'll be displaying the information to the user. Number 3 would be a file on the PC. Although it could also be a file on the FPGA I'm guessing implementing a file system is a little advanced at this point. So you'll probably write some lower level interface to the flash that makes use of the alt_flash_xxx calls you've mentioned. So. write it first on the PC then worry about the FPGA. You know you could consider using uCLinux which would already have a lot of the stuff done for you but you're going to go through a pretty hefty learning curve with it. Jake
