13 years agoData Logging from FPGA to PC
Hi !!! I am still a newbie to digital world. I wish to use the UART in SOPC to send some data to (RS485 interface) my laptop for logging purpose. Laptop does not have a RS485 termin...
13 years agoWhy RS485 and not RS232 or just the UART signals directly from the FPGA?
FTDI have a series of cables that you might be able to use. For example, http://www.digikey.com/product-detail/en/c232hd-ddhsp-0/768-1011-nd/2767783 This cable can be connected directly to 3.3V logic level pins on the FPGA, and those pins can internally connect to a UART inside the FPGA. At that point, you can use standard serial communications on your PC. FTDI show RS485 connections in their data sheets, so they may also have pre-made cables that support RS485. Check out their web site www.ftdichip.com. Cheers, Dave
