13 years agoDAC (DAC5672) and ADC (AD9254) in VHDL
Hi, i have a project in which i need to create the VHDL code for a DAC (DAC5672) and an ADC (AD9254). It is part of a CDMA. The DAC must incorporate a 2's complement and the ADC must incorp...
13 years ago --- Quote Start --- ok, so for the ADC, would this work ? if(clk'event and clk ='1') then
adc_out(12 downto 0) <= analog_in(12 downto 0);
adc_out(13) <= not analog_in(13);
end if; Now the MSB and the rest of the word are synchronised right ? --- Quote End --- Yes, now synchronised --- Quote Start --- And for the DAC, would it be better to replace analog_signal directly with analog_out ? --- Quote End --- Note quite. You'll still have the same problem. Ill let you think about it.... --- Quote Start --- Although i don't see how this will convert a digital signal to an analogue signal... --- Quote End --- It wont, unless this is the number format that your external DAC chip requires.
