18 years agoDAC Converter
Hi, I try to make a DA conversion with this board: http://www.altera.com/products/devkits/altera/kit-dsp-2s60.html But I am not able to make something which works well. When I check my ...
18 years agoIf you intend to use the DAC for low frequency signals or in generally want to keep a DC component at the output, you have to modify the circuit. One option would be to remove T6 and solder a wire between T6.3 and T6.6. You get a single-ended 50 ohms output then. The same for the second channel with T5.
