18 years agoDAC Converter
Hi, I try to make a DA conversion with this board: http://www.altera.com/products/devkits/altera/kit-dsp-2s60.html But I am not able to make something which works well. When I check my ...
18 years agoAn DAC code that works should be the DA/AD performance test provided in the factory design.
I see several points why your test may have no output. Unfortunately none of same can be seen from the information you provided: 1. I don't understand which pin or other source provides the clock to the DAC, 2. As you have a 1.5 Hz divided clock, the DAC ramp has a periof of 3 hours. It may be difficult to observe. 3. The DAC SMA output connector is transformer coupled with Mini-Circuits ADT1-1WT, that has 400 kHz lower cut-off. You can't see any LF or DC signal here.
