13 years agocycloneII standard file(.sof)
Hi all..! I am working on altera 12.0 and i am using cycloneII EP2c20F484C7 kit.i am able to connect this borad with my laptop as well as i run my program successfully.But after compilation of my ...
13 years agoYes I think the easiest way is to install the web edition of Quartus, if you don't have a license.
As for the IP and MAC address, it is entirely up to the embedded software to decide this. If you are using the examples (simple socket server or web server) it will try to read the serial number from the flash and make a MAC address from it. If it doesn't find it, it will ask you for it. Then for the IP address it uses DHCP.
