15 years agocyclone3 fpga device failure
i have designed a board in which i am using 3 cyclone 3 fpga devices. one of them is EP3C16 and other two are EP3C5.one of these EP3C5 deviCes works fine for some days and then automatically gets b...
15 years agoDefault I/O standard for CIII is 3.3V LVTTL or 3.3V LVCMOS which have a current strength of 4 or 2 mA respectively. Did you change the default with a higher strenght value?
I don't know if this could affect DC operation, causing output stage overheating and damage; probably current strenght affects only AC operation, i.e. it improves switching speed. Anyway you'd better check this point. Another point to consider is the maximum consecutive pins driving high current; this must be limited to a value reported in CIII datasheet. Could this be your situation? Do you have many LEDs? I mean 20 or more; if you do, the pin driving them should be spread across banks around the fpga and not concentrated in a single side/corner.
