13 years agoCyclone V Transceiver Synchronised 32bit Word Alignment Problem
I am using the cyclone v gt (http://www.altera.co.uk/products/devkits/altera/kit-cyclone-v-gx.html) demo board in an attempt to get a transceiver channel that has a direct loopback (Tx->Rx) across th...
10 years ago --- Quote Start --- I still haven't managed to get this to work and I am waiting to here back from Altera through a service request on this. I did try a similar method to this one (http://www.alteraforum.com/forum/showthread.php?t=21586&p=154036#post154036) identified on a Stratix IV using the following settings:-
- Word Aligner Pattern Length = 20 (x2 10b symbols)
- Word Aligner Pattern = AA97Ch (D10.2 & K28.5 negative disparity in LSbit serial order)
architecture behaviour of RxBuffer is
-- Word ordering (WO) signals
signal WODetector : std_logic;
signal WODataDelta : std_logic_vector(15 downto 0);
signal WOData : std_logic_vector(31 downto 0);
begin
-- Re-Align detection register
-- Note: when the dword is not synchronised this is asserted when the upper-word is synchronised and identifies the pattern
-- detect (LSB) from the word aligner when the lower-word is not synchronised (prior to the pattern detector).
process (SIMPLTP_RxClk) is
begin
if (rising_edge(SIMPLTP_RxClk)) then
-- Check if the data word is not synchronised (one or more octets within the dword) = capture align detection
if (SIMPLTP_RxData(58) = '0' or SIMPLTP_RxData(42) = '0' or SIMPLTP_RxData(26) = '0' or SIMPLTP_RxData(10) = '0') then
WODetector <= -- Upper word synchronised and pattern detected
SIMPLTP_RxData(58) and SIMPLTP_RxData(44) and SIMPLTP_RxData(42) and
-- Lower word not synchronised
not SIMPLTP_RxData(26) and not SIMPLTP_RxData(10);
else
WODetector <= WODetector;
end if;
end if;
end process;
-- Data/control delta registers
begin
WODataDelta <= SIMPLTP_RxData(55 downto 48) & SIMPLTP_RxData(39 downto 32);
end if;
end process;
-- Word (re)alignment output register
-- Note: either re-aligned or straight depending on the re-alignment detector
process (SIMCL_Reset, SIMPLTP_RxClk) is
begin
if (SIMCL_Reset = '1') then
WOData <= x"00000000";
elsif (rising_edge(SIMPLTP_RxClk)) then
-- Check if a re-alignment is detected and synchronisation established = use delta + current words
if (WODetector = '1') then
WOData <= SIMPLTP_RxData(23 downto 16) & SIMPLTP_RxData(7 downto 0) & WODataDelta;
-- Re-Align not required = retain word order
else
WOData <= SIMPLTP_RxData(55 downto 48) & SIMPLTP_RxData(39 downto 32) &
SIMPLTP_RxData(23 downto 16) & SIMPLTP_RxData(7 downto 0);
end if;
end if;
end process;
-- Physical layer receive buffer data path output
SIMPLRB_Data <= WOData;
end architecture;
--- Quote End --- Thanks lot for the sharing of the working function.
