13 years agoCyclone V Transceiver Synchronised 32bit Word Alignment Problem
I am using the cyclone v gt (http://www.altera.co.uk/products/devkits/altera/kit-cyclone-v-gx.html) demo board in an attempt to get a transceiver channel that has a direct loopback (Tx->Rx) across th...
10 years ago --- Quote Start --- tried to post signaltap attachment again. Hope this one is better.. --- Quote End --- Hi, could you explain more clearly how to byte order pattern? You use two byte pattern 4a and 1bc. So the 18 byte pattern is hex 095BC. Should this pattern be in the "byte order patter (hex)" field of megawizard? Does it works in auto byte ordering mode? Or I must use manual mode with usign rx_std_byteorder_ena port?
