13 years agoCyclone V Transceiver Synchronised 32bit Word Alignment Problem
I am using the cyclone v gt (http://www.altera.co.uk/products/devkits/altera/kit-cyclone-v-gx.html) demo board in an attempt to get a transceiver channel that has a direct loopback (Tx->Rx) across th...
11 years agoYeah the SignalTap capture is a little too small to read.
Can we conclude then from your testing and the work I did originally that to resolve this issue you have to toggle the rx_enapatternalign input after synchronisation to get the dword alignment to work correctly? If this is the case then the transceiver user guide is really weak in divulging this information.
