9 years agoCyclone V SoC Preloader will not run bare metal app
Hello all, I've been working on this problem for several days now. I've read every website/pdf I can find (e.g. these forums, rocketboards, altera pdfs, etc, etc, etc, etc) regarding bare metal...
8 years agoI'm just a beginner myself, so take my advice with a grain of salt, but the options to the mkimage command looks suspect to me:
$(MKIMAGE) -A arm -T standalone -C none -a 0x100040 -e 0 -n "uboot script" -d u-boot.script u-boot.scr I think what you want is something that looks more like that seen in the following web page (URL split with * instead of / to get past spam filter): rocketboards . org * foswiki * Documentation * GSRD131ProgrammingFPGA Here they use: "$ ~/cv_soc_devkit_ghrd/software/spl_bsp/uboot-socfpga/tools/mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n "My script" -d u-boot.txt u-boot.scr" There is another way to get the u-boot.scr script file to work, which allows you to bypass using the mkimage command. When you see this prompt: Hit any key to stop autoboot: 0 Hit a key to stop the boot process. You will be at the bootloader prompt. Then just type in the commands from the u-boot.txt file, one line at a time. Once that works, then there is a way to save these commands in the environment so you don't have to re-type them each time the system boots.
