Cyclone V Gx\GT Optical transceiver support
Support speed range of Cyclone V GX(622Mbps ~ 3.125Gbps) / GT (622Mbps ~ 5.0Gbps).
For #1, Minimum bit rate is 622MHz (max run length is 200 UI). You can refer to CV Datasheet.
For #2, It should be totally balanced. I don't know exact allowable running disparity characteristics, but it should be within +/- 2or3 (<8B10B). You can find the limit by the web search like below.
For #3, Maybe it is AC-coupled configuration, so data toggling is needed to keep balannced signal. Same as #2 it should be DC-balance signal needed for AC-coupling.
Hope this will clarify.
Thank you,
Kshitij Goel
Dear K**bleep**ij Goel,
Do you have any design examples that could test this on a Cyclone V GT development board ? We specifically need a design that will enable us to transmit \ receive between a NIOS and an external optical transceiver ?
Best regards
Shmuel
