13 years agoCyclone V GX evaluation kit question
Hi, I want to use the Cyclone V GX PCIe evaluation kit (http://www.altera.com/products/devkits/altera/kit-cyclone-v-gx.html). I need to design a daughter board that will connect to the FPGA via th...
13 years ago --- Quote Start --- I think that I'll have the voltage translator as a BOM option. The default will be to use serial resistors as you suggested and the voltage translator option will be a fall-back. --- Quote End --- That's a good idea. Its better to have the buffer on the PCB than 'wish' you had it when you encounter a problem that it could solve :) Cheers, Dave
