9 years agoCyclone V Fractional PLLs don't output expected clock frequency
I'm using Quartus 17.0.2. I have trying to generate a 148.5MHz clock with a 50MHz input reference clock. When I put the PLL in fractional mode and enter 148.5M as my target frequency the megawizard s...
9 years ago --- Quote Start --- So I entered the physical parameters manually and it said it could achieve a frequency of 148.4999999MHz. I'm fine with that. So I tried to synthesize the design and I am getting an absolutely bizarre synthesis error:
Error (13305): Verilog HDL error at altera_pll.v(2163): can't find port "refiqclk_1" File: c:/altera/17.0/quartus/libraries/megafunctions/altera_pll.v Line: 2163 This isn't even one of my source files!! O.o I have attached the file that the megawizard generated. I'm not sure what else to say...how can I compete with source files errors in Quartus' own installation directory..........????? --- Quote End --- This looks like an altera library problem. I looked at the same file in my 16.0 install, and I see in the altera_pll.v file: altera_cyclonev_pll# (
cyclonev_pll (
// cyclonev_pll_refclk_select pins
.adjpllin(adjpllin),
.cclk(cclk),
.coreclkin(),
.extswitch(extswitch),
.iqtxrxclkin(),
.plliqclkin(),
.rxiqclkin(),
.clkin({2'b0,refclk1, refclk}),
.refiqclk_0(),
.refiqclk_1(),
.clk0bad(clkbad_wire),
.clk1bad(clkbad_wire),
.pllclksel(activeclk_wire),
// cyclonev_pll_reconfig pins
so it expects refiqclk_0 and refiqclk_1 to be two separate one bit wide ports. But in the referenced altera_cyclonev_pll.v module file I see: module altera_cyclonev_pll(
clkin, // 4
refiqclk_0, // 2
input clkin;
input refiqclk_0;
that refiqclk_0 is a single port that is two bits wide, and refiqclk_1 is a port that does not exist. So there is an inconsistency/error in the base altera library definition files. So it would appear that anybody that has tried to use a fractional PLL in a CycloneV would be getting this error, at least in 16.0 and thru 17.0.2. This is a problem altera needs to fix. However, in the short term one could probably just comment out the reference .refiqclk_1(), on line 2163 of file altera_pll.v as a quick fix, as the ports are not connected and in this context do nothing useful.
