10 years agoCyclone V E: QSPI Flash supported
Hi, I'm conceiving a new Cyclone V E based board implementing a 5CEFA7F23, a DDR, a SRAM and a Flash memory. I wish to configure my FPGA with Asx4 configuration, so I need a QSPI NOR Flash for ...
10 years agoHave a look at this thread (http://www.alteraforum.com/forum/showthread.php?t=50234). I hope it points you in the right direction.
As already stated, the issue is only with the Nios2 Flash Programmer. This work around only applies to that. If you're not looking to use this method of programming your EPCQ (or equivalent) then you don't need to refer to it. Cheers, Alex
